Inventor Forum
select parameter
3 REPLIES 3
j.vanderheijden
413 Views, 3 Replies
select parameter
When i place a rectangel in a sketch i can't select the parameters to be directly linked to size.
I must first enter a number, delete the number and can then through the triangle to the parameter list.
Is it possible to approach  the parameters directly ?
Mvg Jos
Your drawings are only as good as the symbols that complete them...
3 REPLIES 3
mrattray
in reply to: j.vanderheijden
Just type in the name of the parameter that you want to set it to.
Mike (not Matt) Rattray
When I start a rectangular part, I usually define my parameters in the sketch by typing straight into sketch boxes.
e.g. 'width=100mm" and "length=100mm"
It makes it easier to keep track of parameters in a sketch if you right-click -> Dimension Display -> Expression
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
jostroopers
in reply to: waynehelley
I posted a topic in the inventor 2014 beta forum and they wil add it to the list.
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
