Inventor Forum
screw load
2 REPLIES 2
knaveenpai
498 Views, 2 Replies
screw load
Hi Everyone,
I have a problem for you guys where in I need help.
I have two plates bolted  together with M10 socked headed cap screw. In which the top plate is countrebored and relived, the bottom plate is tapped for M10.
I want to check how much load can the screw withstand.
how can i do this in Inventor analysis.
or is there any other way to calculate this
thanks for ur help
regards
Naveen
2 REPLIES 2
Hi knaveenpal,
You can use the Calculation tab of the Bolted Connection tool to do this:
http://inventortrenches.blogspot.com/2011/04/bolt-and-screw-calculations-with-bolted.html
I hope this helps.
Curtis
Hi  Curtis,
thanks for your help
