Hi
my idw is sloooowwwwwwwww. i have 60 sheets and no realise that was a very bad call... Is there a way of saving each sheet as a separate sheet?
Nigel
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
Unless someone has created some code to do this - I think your best bet is to Save As 60 times (delete sheet each time), then open the files and delete the remaining from each.
Nacho
Nacho
Here some of ideas for the manual route:
1. Turn off shading.
2. You can copy-paste single sheets between two open idw files. This may be less work than saving copies and deleting the extra sheets. If you turn on Derfer Updates, this will not work (IV 2014).
3. Create your 60 copies with Windows explorer. Open each file with Defer Updates turned on (options button at the bottom of the file-open window) and delete the unneeded sheets. This should keep IV from recalculating each drawing until you are done with your changes.
4. Is the price of more RAM (so IV doesn't hit the paging file) less the your hourly billing rate times the number of hours it will take you to code (and test) your solution? If so, maybe throw more computer at it.
Steve Walton
Nacho
Hi nmjshaw150
Do you got any solution for the same, I too struck in that same situation.
Can you please provide your solution.
Thanks in advance.
Hi
I did make a solution. I am making it into an app for the store next month so i will drop a link when its done
Nacho
