Inventor General
Distinguished Contributor
cadman777
Message 1 of 8 (280 Views)
save idw to dwg all views full scale w/annotations
280 Views, 7 Replies
06-24-2013 05:00 PM
Is there a way to save an idw sheet to FULL SCALE dwg drg, so that all the views are full scale and also maintain all dimensions and annotations in one uniform scale?
I need to do this for the flat patterns that go to the steel mill to get laser cut, and they want all the pertinent info accompanying the view/part-profile.
Thanks ...
... Chris
IV 2010 Suite
Digital Storm PC:
EVGA & Intel components
Win 7 Pro 64 bit
*Expert Elite*
Cadmanto
Message 2 of 8 (256 Views)
Re: save idw to dwg all views full scale w/annotations
06-25-2013 05:16 AM in reply to: cadman777
Chris,
You might be able to create Predefined Views in a drawing template that is full scale.  Then every view created off of them is what you are looking for.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
cadman777
Message 3 of 8 (246 Views)
06-25-2013 06:24 AM in reply to: Cadmanto
Scott,
Great idea, if only I could make the idw file "auto-generate" a list of parts from disk!
What I'm asking for doesn't seem to make pre-defined views of value.
Basically, after I make a model and detail all the subassemblies for fabrication, I need to create a "flat pattern" sheet for the steel mill. So, on the last sheet/s, I pile as many parts profiles (= only one view) as possible. Last project I had around 50 part profiles on one d-sized sheet.
However, some of those parts are tiny compared to others (like a tank shell flat pattern is huge compared to a small angle flg gusset. So, I want IV to export all views out to dwg or dxf so that all the views are of the same scale, but not lose any annotations/dimensions.
To "cure" this need, thus far I've copied the idw file and delete all sheets with no "flat pattern" views on them. Then I change all views to one scale, one at a time. Then I can export to dwg/dxf and all views are same scale. It takes about 1/2 hour for 50 views, so it's not too bad. But I prefer if IV would do it for me like SW does.
Thanks for your input ...
... Chris
IV 2010 Suite
Digital Storm PC:
Win 7 Pro 64 bit
*Expert Elite*
Cadmanto
Message 4 of 8 (239 Views)
06-25-2013 06:42 AM in reply to: cadman777
Chris,
That's a lot of work. :smileysad:  I know I am not good with iLogic, but this looks like a perfect candidate for a routine to be written.
Best Regards,
Scott McFadden
cadman777
Message 5 of 8 (229 Views)
06-25-2013 08:29 AM in reply to: Cadmanto
Scott,
Great idea. Only thing is, I have 2010 Suite, and don't have the iLogic add-in module for it (not on "Subscription").
No probs. It doesn't matter, as my "work-around" works just fine.
Besides, I was wrong about SW. They can't do anything more than IV can in this matter.
... Chris
IV 2010 Suite
Digital Storm PC:
Win 7 Pro 64 bit
Valued Mentor
coreyparks
Message 6 of 8 (220 Views)
06-25-2013 01:35 PM in reply to: cadman777
I have a VBA routine that exports the flat pattern from within the model and will create and export one if it doesn't exist.  So I open all of my sheetmetal parts and then run the routine and close on each one.  Works great as we don't want anything in our flat patterns but the geometry they need to laser/water jet cut.  Each flat pattern is saved as it's part number and we send a complete print package with as reference in PDF format.  Why wuold they want all the dims in the flat pattern that they then just have to delete or turn off?
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
IV2014 Factory Design Suite Ultimate
Windows 7 64 bit
Synergis Adept document management software
16gb RAM --- Nvidia Quadro 4000 2gb
cadman777
Message 7 of 8 (217 Views)
06-25-2013 02:16 PM in reply to: coreyparks
Corey,
Thanks for that info. Did you write the VBA program yourself, or does it belong to the company?
The reason why the steel mill "needs" the annotations is b/c, as the customer told me, they're "not the brightest lamp on the street", & they have a QC routine that requires some dimensional info. Basically, it saves errors.
If possible, would you mind sharing w/me your VBA program and the instructions?
Cheers ...
... Chris
IV 2010 Suite
Digital Storm PC:
Win 7 Pro 64 bit
Valued Mentor
coreyparks
Message 8 of 8 (197 Views)
06-26-2013 06:30 AM in reply to: cadman777
Have you ever used any VB apps before?  The code gets placed in your Default VBA Project file.  You might want to change the default directory where the files get saved.  If you need specfics on how this needs to work let me know and I will get back to you.
Corey Parks
Windows 7 64 bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
