Hi all,
problem: When using save copy as to make an identical part with a different number, the file name in the top and the browser doesn't update to the new filenumber. only in the bottom file tabs is the name correct. if I go to file> save as I can also see the new filename. This is a hassle when doing this to multiple files in an assembly, as it makes it hard to keep track of which parts have been given a new name. It seems the filename input in the browser is only written once, and that is when the first file was saved for the first time.
Has anyone experienced something like this?
What happens if you close the part out and reopen the part. Does it look ok then?
I ask, because if I have my Inventor session open for a while I can see some strange happenings. Just wonder if that is happening to you as well.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
That doesn't fix it I'm afraid.
I get the impression that the input for the browser is written somewhere hidden in the file.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
That fixed it to the correct filename!
thank you.
However, this was not never necessary earlier, so I'd like to keep the thread open a little longer.
If you renamed the file originally, then this would be an explaination as to why it didn't change, but if you didn't, all three locations should rename automatically after the save as process is complete.
Niels van der Veer
The Netherlands
This happens so often that I can say that I am very certain that I have files that don't update even though I didn't override the filename in the browser. ( I rarely do that, only sometimes but then after this problem has occured.)
This happens to me from time to time as well.
Just happened again this morning.
Deleting the occurence name in the browser does correct it, but it would be nice to know why it occurs...
Regards.
