Inventor Forum
same distance gap around part
2 REPLIES 2
305 Views, 2 Replies
What formula or dimensions do i require so as there is a 0.5mm gap around the Revolution 3 (red color)...is revolution the method required to achieve this?
2 REPLIES 2
You can create two offset planes 0.5 mm from the inside faces of the recessed area, then revolve your red part Between those two planes.
I did it using the method the above poster stated. You had a .75mm gap at the top, I modified your sketch to bring it to .5mm. If this wasn't intended, change it back.
