Inventor Forum
retrieve a bend from sweep ?
11 REPLIES 11
Message 1 of 12
mikkele86
1509 Views, 11 Replies
hello.
I have created a pipe using sweep through 2 planes and 3d sketch. I want a specific bend on that pipe to be extracted for drawing purpose. How do I do that ?
thanks in advance 🙂
11 REPLIES 11
Message 2 of 12
JDMather
in reply to: mikkele86
Can you Retrieve the 2D generating sketches in the drawing?
Message 3 of 12
mikkele86
in reply to: JDMather
dont think so. cant see eny 2d sketch, only 3d.
picture is attached
Message 4 of 12
japike
Can you post the part?
Peace,
Jeff
Inventor 2022
Message 5 of 12
mikkele86
in reply to: japike
yes, here you go 🙂
Message 6 of 12
JDMather
You might have to make them visible in ipt first, I don't recall for sure.
Message 7 of 12
JDMather
If they are not visible in ipt, after retrieving them right click and Include.
Message 8 of 12
mikkele86
ok. I can retrieve the 2D sketch's but how will that help me, retrieve the bend to a standalone part and putting angle dimensions on a bend part ? if you noticed the bend is bended through 2 axis.
I can be more specific, I must find the rotation degrees of that bend and put them on a drawing. 🙂
Message 9 of 12
mikkele86
here an example of what im looking for, but the method is really dirty.
also note the picture, thats the angle im looking for.
Message 10 of 12
japike
Could you add workplanes to your part? Then use the workplanes and the Change View Orientation tool to get the drawing view into the correct orientation.
Peace,
Jeff
Inventor 2022
Message 11 of 12
mikkele86
in reply to: japike
thanks fine sir. It worked. once i got that plane to align with, it was just a matter of show tangent line  🙂
see posted picture for results 🙂
thanks alot
Message 12 of 12
japike
Thank you too! I've never seen Intersection Curve used for a piping run, so I learned something new today. Sweet!!
Peace,
Jeff
Inventor 2022
