Inventor Forum
requesting to save released assemblies when creating a new assembly
3 REPLIES 3
SofiaGrave4819
208 Views, 3 Replies
Hello and greetings to all
I created a new assembly and I placed from vault a released assembly to make a top assembly, but when I want to save the new assembly I get the message that 4050-7 is locked and if I want to continue editing.
Why do I receive this message? I didn’t make any changes to this assembly.
How can I get around this?
See attached file.
Thanks to all
Sophia
3 REPLIES 3
Ok so just to make sure. When you place the assembly in the new assembly, did you use the place from vault command? Then did it ask you "Do you want to check this file out?" and what was your response?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Hej
I used the place from place command.
No prompt requesting to check out file.
Best Regards
SOphia
Do you have the option in Inventor to "Place from Vault"?
Jo - Ann
