Do we have a size limit of the models using replace model reference?
Just done a little testing with some iam's
Anything larger that 500 parts and the drawing does nothing, no replace..
Regards
Warren,
2011
Warren,
Not that I am aware of. Seems to me this might have something more to do with the size/complexity of the models going out and coming in. What are your system specs?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
system not that bad, tried on a few different machines and the same. Anything bigger than 2500 parts falls over.
Typo in the first post.
The work around is the old remane on D, but dont resolve, just remain the name like for like but it is a bit of a pian when vaults involved.
Cheers
Warren.
Do you have Vault in place? I say that because as you mention the rename which I take as possible a copy save as. In vault there is a command called copy design that may or may not work for you.
I have to tell you, I have never heard of a case where a model assembly of the size you are talking about needing to be swapped out or replaced by another.
