Inventor Forum
repeanting a feature as a pattern on a curved surface.
4 REPLIES 4
parody
969 Views, 4 Replies
        I am designing perfume bottles and for that i need to to repeat a semi circle to repeat over a curved surface fo the bottle. To simplify the problem i have created curved surface and made a semi cirle as a feature, now i want the feature to repeat on the curved surface. I have tried to rectangle pattern, aswell as the circular pattern in all possible ways i can think.
        Any help is greatly appreciated. Thanks in advance.
P.s. I have hp I7 processor, 8 gb ram, windows 7 and am using autodesk inventor pro 2013
4 REPLIES 4
mpatchus
in reply to: parody
can you post an example pic of what you want to achieve?
Or a screen cap of what you currently have?
(Can't open 2013 files Smiley Sad )
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
parody
in reply to: mpatchus
 If you see one of the black bottles attached with this message, it has small dots on the it's right side. I want a similar pattern on my design. But cannot figure out how do it.
JDMather
in reply to: parody
You will need to use the Curve Driven Pattern functionality as done in this image.   (see bumps on grips)
http://forums.autodesk.com/autodesk/attachments/autodesk/78/191302/1/Friday%204-7-06_50.jpg
The CADWhisperer YouTube Channel
JDMather
in reply to: JDMather
Did you figure this out?
