Inventor General
Distinguished Contributor
Message 1 of 9 (159 Views)
Accepted Solution
remember the last selection while threading
159 Views, 8 Replies
04-26-2012 10:30 PM
I use INV2013.  I happen import a solid part with lots of holes. I wanted add thread to 15 off existing same size holes.
1.  I am unable to select more than 1 hole at a time to add thread.  Need to go one by one.
2.  But, thread option doesn't remeber the last thread details selected.  So, I need to reenter all the details again.  which is time consuming.
is there any thing can be done to fix this?
Product Support
VinodBalasubramanian
Message 2 of 9 (134 Views)
Re: remember the last selection while threading
05-11-2012 01:44 AM in reply to: rajeshindi
Here is the right way.
Note that the first selection is the crucial one and determines the outcome on the other holes.
Edge selection or face selection is not important on the other holes, it all depends what you have selected on your first hole.
Vinod Balasubramanian
*Expert Elite*
Message 3 of 9 (131 Views)
05-11-2012 02:52 AM in reply to: VinodBalasubramanian
Anyone see the solution (I get a blank).
Are the holes the correct tap drill size?
Is there any kind of regular rectangular or circular pattern that would make Feature Recognition useful?
I might start new sketch and Project Geometry the edges to get centerpoints (toggle to hole centers) and then use the Hole Feature command to place threaded holes in the same location as the existing holes.  Might need to use Delete Face with Heal after creating the sketch.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 4 of 9 (124 Views)
05-11-2012 04:45 AM in reply to: VinodBalasubramanian
Thanks for your reply.
I am unable to select more than 1 hole at a time.  What's more interesting is i am unable to select the edge at all.
r u sure, were you able to select the edge of an hole while THREADING?
Also, while creating secure pin in assembly the problem is same.  I am unable to select more than 1 hole.  But, while creating bolted connection we have the choice to select more than 1 hole.  Why this difference?  Is there any trick involved in selecting multiple holes.  Any help would be appreciated.
Product Support
Message 5 of 9 (106 Views)
05-13-2012 07:32 PM in reply to: rajeshindi
You can use Muliple point in Inventor 2013, to create holes and add threads to it. Please see attached for more info.
Let me know, if you need more info.
Message 6 of 9 (102 Views)
05-13-2012 08:01 PM in reply to: VinodBalasubramanian
But let me make my question very clear,
1.  Can you select more than 1 hole while doing only threading?
2. Can you select more than 1 point to create secure pin in an assembly?
Thanks.
Valued Mentor
Rich.O.3d
Message 7 of 9 (97 Views)
05-13-2012 08:36 PM in reply to: rajeshindi
Guys, he is asking about the thread tool [model tab-modify panel], not the hole tool (with threads) or the bolted connection tool.
To answer your actual question...NO...one at a time only with the thread tool.
I like the idea of multi select...maybe a good wishlist item.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Product Support
Message 8 of 9 (95 Views)
05-13-2012 08:46 PM in reply to: Rich.O.3d
Thanks guys.
As Richos 69 said, you can't do multi select in thread dialog. I can log this as a wishlist item with our development.
However you can use the Multiple point and create holes & threads using that. This would help to create threads for multiple holes.. Thats the only suggestion I have at the moment.
Message 9 of 9 (93 Views)
05-13-2012 09:07 PM in reply to: VinodBalasubramanian
thanks for you both.
Could you also add one more item in the wishlist please,
Having "multiple point selection" while creating "secure Pin" in the assembly please.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
