I made a mistake while doing the Inventor 2014 tutorials. I neglected to save a copy of the original files before I started doing the tutorials. Now, every time I make a wrong move, I am screwing up the original files more and more. Should I completely uninstall Inventor 2014 and reinstall?
Solved by CCarreiras. Go to Solution.
Hi!
No!!! You don't have to uninstall Inventor!!!
You can find the tutorials package in Autodesk sites .
Download it and save a copy.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=21952055
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
