when I use Project Geometry in a 2D sketch, or Include Geometry in a 3D sketch, and later on the geometry I projected/included disappears, the projected/included line in the given sketch becomes broken and is displayed in pink. I do not find the possibility to 'redefine' this line. I can only break the link.
For example, I can redefine a sketch (i.e. select a new surface to define its plane), if the surface on which it was defined disappeared. Would it not make sense to be able to do the same thing with projected lines?
Thank you
Daniel
