Inventor Forum
rail holes
5 REPLIES 5
633 Views, 5 Replies
rail holes
i have 2 questions in which i need some help please
1. How do i place holes in the 2 rails at centre height..the holes placed in the rails so as to place bolt through both rails...i do not know how to place these holes around the curved rails
2. Can these rails be made using Sheet Metal tools.I would like to unfold if possible...not much experience in sheet Metal
All help appreciated
Terry Close
IV-2013
5 REPLIES 5
JDMather
Curve driven pattern (Rectangular Pattern)
read this http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Yes the parts can be made with sheet metal tools (separately).
3D Sketch1 is not needed.
Work Plane2 is a duplication of Work Plane1.
I'll try to come back later and show sheet metal solution.
in reply to: JDMather
Thanks for the attachment...
I will check back later to see your sheet Metal verson
Thank you
JDMather
After thinking about it - no curve driven pattern is needed as this is a sheet metal part.
My solution will have a Contoured Flange, Rolled Flange and a Cut - Across Bend.
Hi JD
Did you find any time to produce the model in sheet Metal?
Thank you
Terry
JD,,,Did you have an opportunity to model up the rail in Sheet Metal
Terry
