Expand the Construction folder.
Right click and try to Copy Object the surface geometry to the modeling environment.
or go to Construction Environment and try Stitching the surfaces.
I get a crash to desktop.
JD,
Thanks for sending this in - I've logged a defect for the crash - I was able to get a CER so we can investigate further.
I was also able to get what seems to be a valid solid though. I went to construction environment & unstitched everything. Then did a quality check on all surfaces, then restitched using a tolerance of 0.004in. Then I could copy that body to back to the part modeling environment. I then used the repair environment to highlight a couple of problems areas, (highlighted with yellow surfaces in the attached). I unstitched, deleted those & then recreated using a boundary patch. Ensure to uncheck the automatic edge chain as there as some very small edges which you should make sureare included for the boundary patch definition.
Where was this data originally created ?
Hope this helps,
Chris
