Is there a command for "rounding down" numbers when working with parameter
equations???
For example, I want to use this equation to determine the number of mounting
holes in a variable length part: # holes = ((overall length - (dist from
end x 2)) / rough hole spacing) rounded down
I will then take this "rounded down" number and use it to determine the
spacing between holes: hole spacing = (overall length - (dist from end x
2)) / (# holes - 1)
I know this can be done by linking to an excel file but I thought there
should be a way to accomplish these equations in IV without having to link
to an excel file.
Is there a better way to accomplish this???
Scott
