Inventor General
Valued Contributor
Message 1 of 5 (606 Views)
"Update All Sheets" icon always visible
606 Views, 4 Replies
06-10-2011 03:55 AM
We use multiple sheets only in case when 1 sheet is has not the sufficiënt space for showing al details of an assembly-drawing.
I'm wondering why the "Update all sheets" icon is allways visible when using more then one sheet in a drawing.
René
Autodesk Inventor Product Design Suite 2013 SP1.1
Product Support
Message 2 of 5 (580 Views)
Re: "Update All Sheets" icon always visible
06-10-2011 11:52 AM in reply to: PolemEngineering
Once you have more than 1 sheet in the drawing the command becomes active and will remain active (as long as you don't turn on "Defer updates" in the document settings) .
I don't think it has the ability to tell you wether an update is actually necessary or not. I think you are expecting too much of the command :-)
Although I perfectly understand your confusion. I would also like the Save button to get disabled when no save is necessary in a document that I have open.  But even Microsoft Office does not offer such a nice touch...
Bob
Active Member
Message 3 of 5 (368 Views)
02-07-2013 12:30 AM in reply to: bobvdd
So, usually, one can tell from the icons that there is an update available but not when you have two sheets. And that is expecting too much of the command? How
Valued Mentor
Message 4 of 5 (353 Views)
02-07-2013 04:16 AM in reply to: bobvdd
It falls into a category of "the lights are on but nobody's home" for sure. Now I know that the Update icon has no meaning once there are two or more drawing sheets in a file. And for all those years I was thinking that the Inventor is telling me that the model has been updated...
Thanks, Bob.
Bob
Web: www.meqc.com.au
Product Support
Message 5 of 5 (338 Views)
02-07-2013 08:10 AM in reply to: andreasenv
The command is only meant to give you the chance to force an update of the one or more views that you have selected. In 99% of the cases this is not necessary and Inventor updates existing views automatically when there is a change. It is just in those 1% of the cases where Inventor does not do it for you , to get the views right.
Bob
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
