Inventor Forum
"The selected component has no volume"
9 REPLIES 9
Message 1 of 10
4555 Views, 9 Replies
I've come across this error message while trying to shell an object.  I am also unable to split the piece, and I have a feeling this lack of volume is the cause of all my problems.
The file was created using a large number of x,y,z coordinates and opens as an apparently solid Inventor part.  Two parts were loaded this way, and I had no trouble with the first.
Is there a way to fix this?
I'm using Autodesk Inventor 2014.
9 REPLIES 9
Message 2 of 10
Cadmanto
Welcome to the forum.
It looks to be an imported part.  In my experience a lot of imported parts are nothing more then surfaces with no real geometry.  In order to shell a part there must be real geometry.  I would try using the thicken command first and then once this command is used you should be able to shell the part.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 10
JDMather
@Anonymous wrote:
...opens as an apparently solid Inventor part. ...
Notice at the top of the browser that it says Surface Body(1).
And  doesn't say Solid Body (1).
Can you zip and attach the original file here
or
the ipt file?
Message 4 of 10
in reply to: JDMather
Even the zipped file is too large to post.
Message 5 of 10
JDMather
Is the zipped original too large (before importing into Inventor)?
Is the Inventor file still too large with the EOP in a rolled up state and zipped?
The file limit is much larger over here http://www.augi.com
Message 6 of 10
trick with large part files #1. Open the part, drag the EOP (End of Part) icon to the top and save the file. Your part will now be at most 350KB if that. When one gets the file all they need do is drag the EOP icon back to the bottom. The sad part: it only works with parts and not assemblies 😞
Message 7 of 10
Okay, here's the file with the EOP moved up.
Message 8 of 10
I figured it out!  I was able to simply stitch the entire object and it then came up as a solid body.  I'm not sure why that didn't work before.
Thanks for everyone's help!
Message 9 of 10
JDMather
When opening the IGES file, before selecting Open, click on Options and check the Import Options, there might be an automatic stitch and check available.
Message 10 of 10
This totally solved my issue with a damned imported delphi part that has been haunting me for over 18 months!
Thank You
