Inventor Forum
"The following style definitions..." issue, please help.
17 REPLIES 17
Message 1 of 18
1435 Views, 17 Replies
I am outright confused over this entire Material and Appearance library fiasco.  I don't know what's going on or how to fix it but every time I open a template I get and error message saying, "The following style definitions C:\my pathway differ from the definitions in the style library..."  Then it lists things like Color: Aluminum - Flat, Color: Blue - Wall Paint - Glossy, etc etc.
I cannot seem to fix this or get it to go away, it's driving me insane and it does it with any and all of my templates.  What do I do to fix this?
17 REPLIES 17
Message 2 of 18
SBix26
Open your template, purge materials and appearances that aren't used, then update from the library.  Save.
That is, use the Purge Styles tool to get rid of unneeded M&A from the file, then make sure that the ones left in the file match your libraries.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Message 3 of 18
in reply to: SBix26
After purging styles, I hit update but nothing is there to update.  What do I do now?
Message 4 of 18
SBix26
I think you've taken care of it.  Now when you use this template to create a new part, there shouldn't be any mismatch.
Sounds as if your template had a bunch of materials and appearances that were not being used, and that didn't match the library.  So, you got rid of the unused ones, and whatever is left matches the library, so you should be ready to use it without the annoying message.
Sam B
Message 5 of 18
in reply to: SBix26
I am still getting the same message.
Message 6 of 18
SBix26
Are you using the same M&A libraries when you edit the template?  If so, I have no idea how this could happen.
Sam B
Message 7 of 18
in reply to: SBix26
I dunno, how do I find that out?
Message 8 of 18
pbrooke
Check in projects and make sure your style library is set to read-write.
IV2012 Product Design Suite
Windows XP Professional 32 Bit
Message 9 of 18
SBix26
OK, I just noticed your signature.  Disregard most of what I've written about Materials & Appearances, because that's all new in 2013.
In 2012 (and earlier versions), the Materials and Colors are part of the Styles Library.  The SL is what the Design Data file path points to.  So, in your .ipj file, under Folder Options, what is Design Data set to?
Sam B
Message 10 of 18
in reply to: SBix26
I'm sorry, I do have the 2013 version, just got it recently and I didn't change my sig.
Message 11 of 18
in reply to: pbrooke
Yes, style library is set to read/write.
Message 12 of 18
SBix26
Are you using the same project (.ipj) when you edit your template and when you start a new file?  If so, can you post a screen shot of that project open in the Project Editor, with both the Appearance Libraries and Material Libraries expanded?
Sam B
Message 13 of 18
cwhetten
in reply to: SBix26
I have the same problem in 2012.  I have purged and updated and saved to the styles library many times, and no matter what I do, this message continues to appear whenever I use one of my templates.  I can't make it go away.  Many of our users have this issue.
This only started happening about 6 months ago or so.  Maybe related to an update?  I don't know.
-cwhetten
Message 14 of 18
in reply to: SBix26
Sam B
Is this what you were asking for?
Message 15 of 18
SBix26
Yes, that's what I was asking for.  Do you use that project for editing templates and for your regular work?
Sam B
Message 16 of 18
in reply to: SBix26
Well my templates are stored in a different folder.  They are not in that project location.
Message 17 of 18
SBix26
Right, but I'm trying to find out if you are using the same M & A libraries when you are editing the templates as you are when you start a new part and get this
Sam B
still waiting for a foreshortened radius dimensioning tool in Drawing Managermessage.
Message 18 of 18
in reply to: SBix26
It appears that there was a subfolder with copies of the templates I was using and I was opening them by mistake.  The templates I'm actually using open up fine.  The problem has been solved... er well, it's been solved for a while now, I just did not notice because I was opening the wrong templates.
