Inventor Forum
"Select Other" pop-up menu gets disabled - IV2014SP2
3 REPLIES 3
graemev
486 Views, 3 Replies
When selecting geometry for, say, the Measure tool, Inventor will occasionally disable the Select Other pop-up menu.  Right-clicking to pick Select Other also fails, which is likely due to the cursor now having lost the original screen location of selection.  Restarting Inventor clears the problem.  I have yet to determine a common workflow or cause for this failure - it seems to be somewhat random.
I am also running a 3DConnexion Space Explorer, so there may be some kind of conflict if manipulating the view during the selection process.
Has anyone else experienced this behaviour?
3 REPLIES 3
in reply to: graemev
Have never had that happen here.
johnsonshiue
Hi! This is the first time I heard about the behavior also. Could you try the following and see if it makes a difference?
1) Go to Tools -> Application Options -> General -> go to lower right corner of the dialog -> change "Select Other" delay to 10 sec -> Apply -> OK.
It should let Select Other stay very long.
2) If #1 does not help, go to Tools -> Add-Ins -> unload 3DConnexion Add-In.
Thanks!
Software Test Engineer
graemev
in reply to: johnsonshiue
Thanks!
1)  This only makes it take 10 seconds to appear.  It was previously set to 1 second and worked just fine that way.  I've never had a problem with the pop-up failing to linger.
2)  I do not appear to be able to unload the add-in, though I may simply be missing the secret golden key.
