Inventor General
Member
tkuhl
Message 1 of 8 (947 Views)
"Rotate at angle" command only available when creating a custom view.
947 Views, 7 Replies
10-01-2012 07:15 AM
Is there any way to use the "Rotate at angle" command outside of the "custom view" environment?
Is there actually any technical reason why the controlls in the attached screenshot are not available in the Studio and normal modelling environments?
Thanks.
*Pro
jletcher
Message 2 of 8 (941 Views)
Re: "Rotate at angle" command only available when creating a custom vi
10-01-2012 07:19 AM in reply to: tkuhl
1) You don't tell us what version of Inventor you are using.
2) You did not attach screenshot.
3) are you trying to rotate a view at a given angle?
4) provide screenshot of what you are trying to rotate..
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
JDMather
Message 3 of 8 (939 Views)
10-01-2012 07:20 AM in reply to: tkuhl
You can rotate in Studio (but I don't understand how that would address your drawing view issue) or you can Move Bodies - Rotate.
http://wikihelp.autodesk.com/enu?adskContextId=REDIRECT_IDD_PM_TRANSFORM&language=ENU&release=2013&p...
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
tkuhl
Message 4 of 8 (921 Views)
10-01-2012 07:50 AM in reply to: JDMather
Thank you for the swift reply.
I am trying to render images from inventor studio with a camera view that is a given angle to and distance from the model. My method so far has been to try and find a rotation tool that accepts precision input and then render an image from the current camera view.
My question probably should have been "Are there any tools to precicely control rotation (like the custom view tools) available when using Inventor studio."
Thanks.
PS:
Autodesk Product Design Suite Premium 2013, Build 138
JDMather
Message 5 of 8 (916 Views)
10-01-2012 07:56 AM in reply to: tkuhl
I missed that portion of your original problem description.  I'm sure there is a way (one-way or another) to get angle(s) you want.
Member
tkuhl
Message 6 of 8 (905 Views)
10-01-2012 08:23 AM in reply to: JDMather
Thanks, I'll see if I get any suggestions!
Curtis_Waguespack
Message 7 of 8 (896 Views)
10-01-2012 08:59 AM in reply to: tkuhl
Hi tkuhl,
I've run into this need with our Marketing department who wanted renders from the exact camera angle for all of our family of products. The solution I used was to create a "studio camera box assembly".
I used work points created on a surface box to set the precise camera locations and angles, and then just use this assembly as a template into which the product assemblies are dropped into.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Member
tkuhl
Message 8 of 8 (848 Views)
10-05-2012 04:31 AM in reply to: Curtis_Waguespack
Hi Curtis,
Thank you very much - that got me out of trouble!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
