Inventor Forum
"Fixed" placed components with one constraint
12 REPLIES 12
Message 1 of 13
9283 Views, 12 Replies
Why can I not constrain placed objects with three constraints? Anything I place constrains with one constraint then is virtually fixed (without being) and cannot even be moved to allow for further constraining.
Any ideas?
Nick
12 REPLIES 12
Message 2 of 13
....in addition, this only applies to one assembly alone. Is this a setting for this assembly or is it cpossibly corrupted?
Message 3 of 13
mcgyvr
any grounded parts?
any imported parts?
Message 4 of 13
stephengibson76
does it move if you put another constraint on it, sometimes you cant drag components.  Also try view, degrees of freedom
Stephen Gibson
View stephen gibson's profile on LinkedIn
Message 5 of 13
in reply to: mcgyvr
No grounded parts or imprts just a placed assembly that "grounds" on the first constraint.
Since then I have found that i can still add constraints. I can't physically move it after the first constraint but can move it via the addition of other constraints!
Thanks for the help, think i'll just file this under weird!
Message 6 of 13
Thanks Stephen
It looks that way! No reasons for why it doesn't move manually?
Cheers
Nick
Message 7 of 13
mrattray
I've had that happen to me before. It's like certain parts/assemblies piss Inventor off. Usually I find sick mates or featues in the problem component. I find that using the move command instead of just dragging works fine.
Mike (not Matt) Rattray
Message 8 of 13
benemt
I am having this same problem with a certain assembly.  It has many parts that have already been fully or partially constrained.  Everything that has at least one constraint on it appears fixed even if it had been "movable" earlier.  I can't post the file as it is proprietary but wanted to check and see if this was ever truly solved.
Thanks.
Message 9 of 13
mrattray
in reply to: benemt
Are there sick mates anywhere in the assembly? Are there any sick features on the parts in question? Are any of the parts in interference with each other?
Message 10 of 13
benemt
in reply to: mrattray
No, no, and no it seems.  The parts move normally if they have no constraints but as soon as you add one constraint (even if its to a part that previously had no constraints as well), the parts are "fixed."  I can still add more constraints and get it to align somewhere else that way though.
I have "Updated" the whole assembly and tried "Rebuild All" and still have the same problem.  This is the first time this is happening with this assembly as I have been working with it for about a week.  I don't know what has changed.
Using Inventor 2012.
Message 11 of 13
benemt
in reply to: benemt
I figured it out, kind of.  I made a copy of the assembly and then methodically deleted components until the proper behavior was restored.  I was able to determine that a single part was causing the issue and when I deleted it, it went back to normal.  I then went through all of that components constraints and found that two of the "inserts" were specifically causing the problem even though they were not showing errors and appeared compliant.
When I examine the parts these were constrained to, I see how things could possible be slightly off in these two constraints based upon different mates (as the parts are related both directly and indirectly through constriants).  It's just strange that the constraints were still built "correctly" and appeared to work but were actually having problems.
-Marked as Solution-
Message 12 of 13
lkrenzler
in reply to: benemt
I'm definately having this same issue.  It really is hard to track down where the problem is.
Inventor Pro 2019 - Win. 10 - GeForce GTX 1080 .
Message 13 of 13
allenliuyy
in reply to: lkrenzler
Today is Friday, March 24, 2017, I got this problem a few times in a assembly in this week. I am using Inventor Pro 2017. I have this problem now. So I am trying to find solution from the forum.
I made this problem go away by restarting Inventor last time, but it happened again today in a different assembly. I do not want to restart Inventor from time to time. what is the reason for this problem.
Help please.
Thanks.
