Inventor General
Distinguished Contributor
randallgraham4313
Message 1 of 6 (1,068 Views)
"Find Assembly Components" question
1068 Views, 5 Replies
05-17-2011 05:56 AM
I have a very large assembly and am trying to find where a component is in the assembly. I open the "Find Assembly Components"  binocular icon above the browser and no matter what number I plug in, it can't find it. Even when I plug a number that is visible in the browser, it can't find it. I am obviously doing something wrong in what I am plugging into this diag box. Does anyone have any helpful suggestions for me? Thanks
Randall
Active Member
daltec2
Message 2 of 6 (1,050 Views)
Re: "Find Assembly Components" question
05-17-2011 06:56 AM in reply to: randallgraham4313
When i fill out the following info in the "Find Assembly Components" it finds the Component/part/assembly im searching for.
randallgraham4313
Message 3 of 6 (1,038 Views)
05-17-2011 07:34 AM in reply to: daltec2
I tried what you suggested and it works to a disappointing level. The part I am searching for is buried in a sub-assy and
after the search I could not find it highlighted anywhere. I did find it when I did an 'expand all' then I had to scroll thru maybe 40 screens on the browser, then I located it. In the perfect world, and I have seen this on other systems, when you do a search for a part, it would automatically highlight it and it would expand only the appropriate sub assy and put it at the top of the browser window. Unless someone can show me a setting I need to activate, I would need to expand all and manually scroll thru the whole browser to find the component. I hope there is an easier way. Any suggestions? Thanks
Randall
randallgraham4313
Message 4 of 6 (999 Views)
05-17-2011 11:43 AM in reply to: randallgraham4313
This is a difficult thing to describe but allow me to explain further. If you highlight a part in your model  and initiate the command  ' find in browser' , the item is highlighted in your browser and you are directed to the highlighted item. If you highlight an item listed in the browser, and initiate the command 'find in window' , the machine zooms to the part in your display area and highlights it. When I do a 'find assembly component' command even if it finds it, I have to 'expand all' and start scrolling thru the browser menu's. And on a large assembly, there could be hundreds of screens. If that is just the way it is, I can accept that too. I just need to know if I should stop looking.
Randall
Member
rolabendan
Message 5 of 6 (884 Views)
08-30-2012 05:00 AM in reply to: randallgraham4313
It'd be nice if the "Find Assembly Components" command presented the number of instances it found, as well.
Active Contributor
stephenrottloff7259
Message 6 of 6 (679 Views)
03-13-2013 02:41 PM in reply to: randallgraham4313
Most of the time you use the find tool because most parts are hidden within an assembly, and, you normally work with the shaded view on.  Switch to wireframe mode first, then use the find tool.  Even though the model tree may not get expanded to show the found parts, they will be highlighted in the model view and are easy to locate in 3D space.
Stephen R.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
