When I dimension a sketch manually, the dimensions are usually placed inside the dimension lines. However, when I dimension it using iLogic, the arrows are placed outside the dimension line and it create a real mess. Is there any option or code snippet that can control whether the sketch dimensions are located inside or outside of the dimension extension lines.
See attached image for details. I would like my dimensions to be like the image on the left.
Steve
Are you using a style in your code. If you call out to use a style that have the dimesions the way you want them it should work..
How do I reference a dimension style in my iLogic code for a part sketch? I didn't realize that dimension styles were available when creating part sketches.
Steve
Sorry I did not see in your first post it was a part... Did not even look at your pic till now is this Inventor? Looks like Autocad
But you are correct in part modeling there is no dims style that can be set to my knowledge.
Not sure there is a way
Yes, it's Inventor. I'm just using the dark colour style.
Maybe someone at Autodesk has an idea on this and could respond.
Steve
