Inventor General
Member
gmcnaer19
Message 1 of 11 (1,196 Views)
"An unnamed file contains an incorrect path" IGS files "Inventor2010"
1196 Views, 10 Replies
04-11-2012 09:20 AM
When i attempt to open an IGS file i get "an unnnamed files contains an incorrect path"
  1. I thought it could have been a corrupted file but its not.
  2. Tried to create my own IGS file (successful) attempted to open that and failed.
  3. Downloaded an IGS file from Autodesk, failed as well.
  4. I was having issues opening other files but i updated the video drivers on my Dell M6600. Fixed that issue.
Any idas would be helpful? i dont really want to pay $200 to Autodesk to assist.
thanks,
Distinguished Mentor
rdyson
Message 2 of 11 (1,193 Views)
Re: "An unnamed file contains an incorrect path" IGS files "Inven
04-11-2012 09:24 AM in reply to: gmcnaer19
Repair Install?
May not work, but worth a try.
Member
gmcnaer19
Message 3 of 11 (1,191 Views)
04-11-2012 09:25 AM in reply to: rdyson
I did an uninstall from add/remove programs. Still having the issue. Any other ideas?
thanks,
Member
gmcnaer19
Message 4 of 11 (1,184 Views)
04-11-2012 09:30 AM in reply to: rdyson
any other ideas buddy?
*Expert Elite*
JDMather
Message 5 of 11 (1,181 Views)
04-11-2012 09:33 AM in reply to: gmcnaer19
1. How do you know it is not corrupted if you can't open it?
2. How do you know you were successful creating  if opening failed?
Did you follow the Autodesk document for Clean Uninstall when you did the uninstall/reinstall?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13187758&linkID=9242018
Did you turn off UAC and anti-virus during reinstall?
Do you have Options set to not create html report?
Attach an IGES that YOU created here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
gmcnaer19
Message 6 of 11 (1,175 Views)
04-11-2012 09:43 AM in reply to: JDMather
I am having the guy who uses Inventor to send me the file. Will you test it on your end? please check my answers in red.
I dont, we only have one user using inventor, so i will send it to you and see if you can open.
That i am not sure, we were able to create it without any errors.
Yes
Where is this found?
*Expert Elite*
JDMather
Message 7 of 11 (1,171 Views)
04-11-2012 10:00 AM in reply to: gmcnaer19
In Options when opening the file.
Member
gmcnaer19
Message 8 of 11 (1,164 Views)
04-11-2012 10:09 AM in reply to: JDMather
Where do i access that?
*Expert Elite*
JDMather
Message 9 of 11 (1,149 Views)
04-11-2012 11:31 AM in reply to: gmcnaer19
I don't recall if it was in 2010.
Select file to import (but don't open yet).
Click Options
You might have to search around here for a Registry edit for 2010 if it was not available in the dialog box.
There was a problem caused by this report generation on some machines.
*Pro
ampster
Message 10 of 11 (1,144 Views)
04-11-2012 12:19 PM in reply to: JDMather
JD, was it a registry edit or environment variable you are reffering to?
http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-freeze-and-crash-when-opening-STEP-files/m-...
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
