Inventor General
New Member
ANDREWLEED6659
Message 11 of 19 (524 Views)
Re: "A cyclical constraint dependancy was detected" error message
06-19-2012 10:53 PM in reply to: Desam
I have had this issue when using Inventor 2013. A Customer Support Case has been running for weeks .........
Until a solution is found, I can't afford to use version 2013.....
Andrew
Product Support
VinodBalasubramanian
Message 12 of 19 (523 Views)
06-19-2012 10:56 PM in reply to: ANDREWLEED6659
Thanks Andrew. Currently we are actively looking into this issue and will be addressing it as soon as possible. I will keep you all posted with an update soon.
Vinod Balasubramanian
Active Contributor
martin.vanecek
Message 13 of 19 (467 Views)
07-23-2012 02:29 AM in reply to: ANDREWLEED6659
Hello
We have the same problem, one of our VIP customers.
The estimate of the time when the fix?
We need, to communicate to the customer.
Thanks for info
Employee
ChrisMitchell01
Message 14 of 19 (459 Views)
07-23-2012 08:38 PM in reply to: martin.vanecek
A fix for this will be released in an "Update2" in early August. If you want to get access to that specific fix (as well as various others), before then, there is also an SP1 beta project underway now, which contains the fix. If you haven't received an invite yet, then let me know offline & I'll provide access.
Chris
chrisDOTmitchellATautodeskDOTcom
Chris Mitchell
Inventor Customer Engagement Team
Active Member
longoriaos
Message 15 of 19 (359 Views)
12-13-2012 12:30 PM in reply to: Desam
I have the same problem when crreating a part from an assembliy, so far it work by breaking the link .
Rigth click on the part name then select break the link
Desam
Message 16 of 19 (347 Views)
12-13-2012 03:27 PM in reply to: longoriaos
You might want to try SP1.1 as this fixes the problem for me.
regards,
Hugh
Active Contributor
ic198
Message 17 of 19 (270 Views)
04-03-2013 06:35 PM in reply to: Desam
I'm still finding this problem in SP1.1- is anyone else?
New Member
WinsAuto1
Message 18 of 19 (44 Views)
06-02-2014 07:28 AM in reply to: VinodBalasubramanian
Has this error been resolved.  I currently am operating Inventor 2014 and the program is totally locked up, with the cyclical error message.  How do I get out of the program to even move ahead?
Employee
ChrisMitchell01
Message 19 of 19 (38 Views)
06-02-2014 12:21 PM in reply to: WinsAuto1
Which version of 2014 are you using ? Some fixes related to this were released in SP1.1; that has since been updated to SP2.
Can you provide any example files ?
Chris
Chris Mitchell
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
