Inventor General
Message 1 of 17 (1,222 Views)
"A cyclical constraint dependancy was detected" error message
1222 Views, 16 Replies
04-26-2012 06:32 PM
Am getting this error "A cyclical constraint dependancy was detected" when attempting to rebuild derived parts with any skeleton base project I work on in Inventor 2013.  Skeleton part rebuilds fine with no errors shown but part will not rebuild.  Error message does not allow me to chase down any problems either.  Just have to abandon 2013 and go back to 2012.  Am not very happy.
Is any one else experiencing this?
Files too large to add to post (less than 3mb but larger than 1.5mb posting attachment limit)  am happy to send/upload to any one interested
regards.
Hugh Ralton
DSAM Drafting
Windows 7 64bit
Product Design Suite Premium 2013 (Inventor 2013)
*Pro
sbixler
Message 2 of 17 (1,200 Views)
Re: "A cyclical constraint dependancy was detected" error message
04-27-2012 04:05 AM in reply to: Desam
Pull the End of Part marker on each part all the way to the top (making the part invisible), then save and zip.  That may make them small enough to be attached here.
Message 3 of 17 (1,182 Views)
04-27-2012 04:50 PM in reply to: sbixler
Hi Sam,
Have tried that but still too big.  Have tried to reduce skeleton size but unfortunately this temporarily clears error.  Am not able to reproduce error on small scale yet either.  I have submitted files to autodesk and am thinking that others will also see this error independantly in the future and hoping that it will be dealt with then.  Am plodding along back in 2012 for the forseable future.
Thankyou for your reply.
Hugh
Active Member
Message 4 of 17 (1,142 Views)
05-17-2012 12:43 AM in reply to: Desam
I am having exactly the same problem after upgrading to 2013. I created this 'shed' in 2012 and it all worked sweet! upgrade to 2013, and I have LOTS of problematic parts.
I have attached 3 parts.
1. 'SITE LAYOUT.ipt' is the skeleton. no problems with this file (that i know of - many other parts built off this and work ok. and EVERYTHING worked in 2012)
2. Panel 'P1.ipt' is the prime example of the issue. mod the skeleton, update P1 and you get the '"A cyclical constraint dependancy was detected" error message. Interesting considering I haven't added any sketch geometry, it all comes from the skeleton. I cannot do anything (that i know of) to fix it other than completely rebuild it and repair all broken constraints. times this by the number of busted parts = fun for me.
3. 'BLAST ROOF PANEL.ipt' is a different issue but is VERY common in 2013 for me. again tweak the skeleton, update the part and extrusion 2 throws up an error. fix it by editing extrusion 1 and returning. do this every time I tweak the skeleton times by the number of problematic parts = more fun for me.
Very frustrating. Please help.
Message 5 of 17 (1,140 Views)
05-17-2012 01:31 AM in reply to: ifsi
Am sorry  to hear you are having the same problem but not surprised unfortunately.  Back to 2012 for you too I suppose?  Another person I work with has also had exactly the same problem.  We have both submitted a support request to autodesk and got this response
Thanks for your reminder. I have checked with our developers. They are planning to fix this as a part of service pack for Inventor. I will let you know the dates as soon as i have an update from our development team.
Do let me know, if you have any concern. I would give a call to discuss further.
Looking forward to your updates.
Best regards,
Vinod Kumar Balasubramanian
Autodesk Support Team"
Over to you Autodesk
regards
Hugh
Product Support
VinodBalasubramanian
Message 6 of 17 (1,123 Views)
05-17-2012 04:45 PM in reply to: Desam
Thanks Hugh. We have received a few reports so far on this. I am working with our developers to find out any workaround, if possible. Currently this issue is work in progress and will keep you all posted with an update soon.
Vinod Balasubramanian
Employee
Message 7 of 17 (1,103 Views)
05-18-2012 05:32 PM in reply to: Desam
We have this problem fixed in an internal build.
Thank you for bringing it to our attention.
John Hahn-Francini
Autodesk Inventor developer
Active Member
Message 8 of 17 (1,076 Views)
05-27-2012 08:33 PM in reply to: john.hahn-francini
That is great!
Any chance we can get that as a hot-fix?
Employee
Message 9 of 17 (1,056 Views)
05-29-2012 07:41 AM in reply to: Desam
Our customer service team is looking into the best way to deliver the fix. They are very well aware that this problem is causing customers a lot of grief.
John Hahn-Francini
Autodesk developer
Active Member
Message 10 of 17 (1,025 Views)
06-19-2012 10:26 PM in reply to: Desam
Bump - Any progress on delivering a fix for this issue?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
