Inventor Forum
punch tool cuases Inventor 2013 to shutdown
6 REPLIES 6
433 Views, 6 Replies
Any ideas why the Punch i created causes the following?
1. The punch will not work with part 1.I have 4 points for the Punch on part-1
2. When attempting to get the 4 punch holes on to the flat sheet it causes inventor to shutdown.I have done 4 attempts to fit the punch into the flat sheet (part-1) and 4 times it has shutdown Inventor
Tony
6 REPLIES 6
mrattray
You're not by chance a SolidWorks user, are you? It looks like you're setting your punches up like you're in SolidWorks.
Inventor wants an ide file for the punch tool, not an ipt.
With your punch0 file open go to the manage tab and click "extract iFeature". This will allow you to create the ide file which you will then use to do your punching with.
Mike (not Matt) Rattray
AAHH....silly me i forgot to send the punch as well.I had the Punch made already which was causing me grief.but i forgot to send with other 2 files.
Here is the Punch
Thanks mrattray
Tborland
mrattray
My IV crashed when I tried to insert it, too.
So I did some digging and discovered that you drew this feature on a 1mm thick sheet and the part you are punching is 2mm thick. Normally this is ok, but the way that you drew the feature causes it to fail when applied to the thick sheet.
I applied your punch to a new part that I made that was 2mm thick. IV did not crash but instead gave an error message about one of the chamfers in the iFeature failing.
I changed the thickness of part1 to 1mm and it worked fine. Try redrawing your iFeature geometry to be more "parametric" then it is so that it will work with different thicknesses. I suggest using a single revolve feature for this, anyways. Ditch all these fillets and chamfers and extrusions.
in reply to: mrattray
thanks mrattray
Thanks for the help of punch
If you have time could you do up the part with the geometry being "parametric"  so that it will work with different thicknesses. I suggest using a single revolve feature.I could then study the technique so as i get better understanding of ifeature for punches.I want to make different punches
Cheers
TBorland
I had another attempt with your suggestions.I used a revolve feature but it will not save as a Sheet Metal Punch iFeature.What do i need to change to get this part to save as a Punch .ide
Regards
Tony
bump??
