Inventor Forum
propeller
8 REPLIES 8
Message 1 of 9
harold_kennedy
4676 Views, 8 Replies
propeller
Hi all
How are complex shapes created in Inventor.I have started a propeller but at this point am only able to do the hub.Could a sample be posted in Inventor 2013 on how to create the propeller blades.Is this modelling for this shape done with surface modelling or can it be created with solid modelling technique?
It would be good if a sample is posted of how you would model the blade as such in the picture
Best Regards
Harold
Inventoir 2013 Education version
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: harold_kennedy
This question has been asked here several times in the past.
If a search doesn't turn up a solution, post back and I'm sure someone will post an example solution.
Message 3 of 9
harold_kennedy
in reply to: JDMather
I did a quick search..not much to go on..hopefully someone will post an example
Message 4 of 9
JDMather
Check this one first, them I'll find some others
http://forums.autodesk.com/t5/Autodesk-Inventor/Boat-prop-models/m-p/1533804#M179996
Oops, never mind - the how to on that one is dead.
Let me look some more.
Message 5 of 9
Paul-Mason
The attached 4 page PDF, (Version 6 most PFD readers will open this version) file may be of some help, page 4 of this file may give a suggestions as how to proceed by using a series of sketches at the calculated pitch angle and one or more of the profile to form a series of lofts
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 6 of 9
stevec781
in reply to: Paul-Mason
A propeller is just a screw so use the coil tool.
Draw the cross section
Use coil to input pitch
Sketch the projected blade area shape that you want and cut it down to 1 blade
pattern the blade.
Not an exact method for production but good enough to make a simple model for visualisation
Message 7 of 9
mpatchus
I used to use prop data similar to this as an excercise for my advanced students.  It usually gave most of them fits, but occaisionally one would solve it.
I've included the files (Inventor 2012) if you wish to see how this model was constructued.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 8 of 9
JDMather
in reply to: mpatchus
Harold - are you still working on this?
I'm sure you can get plenty of help here but you will have to indicated a continued interest in solving the problem.
Message 9 of 9
I am definately still interested.Mike that is a excellent model and JD i would like to learn how to create (even start) on those blades..It will take me a little time but i would like to learn to model like that..
Cheers
Harold
