Inventor General
Active Contributor
harold_kennedy
Message 1 of 9 (1,000 Views)
propeller
1000 Views, 8 Replies
12-07-2012 04:12 AM
Hi all
How are complex shapes created in Inventor.I have started a propeller but at this point am only able to do the hub.Could a sample be posted in Inventor 2013 on how to create the propeller blades.Is this modelling for this shape done with surface modelling or can it be created with solid modelling technique?
It would be good if a sample is posted of how you would model the blade as such in the picture
Best Regards
Harold
Inventoir 2013 Education version
JDMather
Message 2 of 9 (997 Views)
Re: propeller
12-07-2012 04:22 AM in reply to: harold_kennedy
This question has been asked here several times in the past.
If a search doesn't turn up a solution, post back and I'm sure someone will post an example solution.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Contributor
harold_kennedy
Message 3 of 9 (990 Views)
Re: propeller
12-07-2012 04:47 AM in reply to: JDMather
I did a quick search..not much to go on..hopefully someone will post an example
JDMather
Message 4 of 9 (963 Views)
Re: propeller
12-07-2012 07:42 AM in reply to: harold_kennedy
Check this one first, them I'll find some others
http://forums.autodesk.com/t5/Autodesk-Inventor/Boat-prop-models/m-p/1533804#M179996
Oops, never mind - the how to on that one is dead.
Let me look some more.
Valued Mentor
Mason-Paul
Message 5 of 9 (950 Views)
Re: propeller
12-07-2012 09:01 AM in reply to: harold_kennedy
The attached 4 page PDF, (Version 6 most PFD readers will open this version) file may be of some help, page 4 of this file may give a suggestions as how to proceed by using a series of sketches at the calculated pitch angle and one or more of the profile to form a series of lofts
Inventor 2014 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Ghz CPU , 32 GB Ram
64bit Windows 7 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Valued Mentor
stevec781
Message 6 of 9 (838 Views)
Re: propeller
12-11-2012 06:25 AM in reply to: Mason-Paul
A propeller is just a screw so use the coil tool.
Draw the cross section
Use coil to input pitch
Sketch the projected blade area shape that you want and cut it down to 1 blade
pattern the blade.
Not an exact method for production but good enough to make a simple model for visualisation
Valued Mentor
mpatchus
Message 7 of 9 (818 Views)
Re: propeller
12-11-2012 09:11 AM in reply to: Mason-Paul
I used to use prop data similar to this as an excercise for my advanced students.  It usually gave most of them fits, but occaisionally one would solve it.
I've included the files (Inventor 2012) if you wish to see how this model was constructued.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
JDMather
Message 8 of 9 (816 Views)
Re: propeller
12-11-2012 09:16 AM in reply to: mpatchus
Harold - are you still working on this?
I'm sure you can get plenty of help here but you will have to indicated a continued interest in solving the problem.
Active Contributor
harold_kennedy
Message 9 of 9 (780 Views)
Re: propeller
12-12-2012 04:06 AM in reply to: harold_kennedy
I am definately still interested.Mike that is a excellent model and JD i would like to learn how to create (even start) on those blades..It will take me a little time but i would like to learn to model like that..
Cheers
Harold
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
