Inventor Forum
programming snippets, ilogic - measure.extentsLength
4 REPLIES 4
2647 Views, 4 Replies
Hi, I am a programmer and im trying to use the 'Measure.ExtentsLength', 'Measure.ExtentsHeight' & 'Measure.ExtentsWidth' found in the snippets which inventors ilogic offers.
a (correct/working) rule that i currently have working in a part document is:
Dim Length As Integer = 0
Dim Height As Integer = 0
Dim Width As Integer = 0
Length = Measure.ExtentsLength
Height = Measure.ExtentsHeight
Width = Measure.ExtentsWidth
however when i am programming in vb.net/c++ my code is:
Dim InvApp As Inventor.Application
Dim PartDoc As InvApp.PartDocument = "filepath of part"
MsgBox(PartDoc.Measure.ExtentsLength) '<---------error
what are the librarys/headers that I have to declare find the Measure.ExtentsLength?
Thanks in advance, Craig
4 REPLIES 4
jletcher
What are you trying to do there is very little on ilogic be better if you tell use what you are trying to do.
in reply to: jletcher
My program will create a drawing from any part. Below is the complete - working ilogic rule, that i am trying to translate over to my stand-alone program.
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
' UPDATE PROPERTIES'
iLogicVb.RunRule("Update Properties")
'END UPDATE PROPERTIES'
Dim oDrawDoc as DrawingDocument
Dim oPartDoc as Document
Dim oSheet As sheet
Dim oTG As TransientGeometry
Dim oBaseView As DrawingView
Dim oView2 as DrawingView
Dim oView3 as DrawingView
Dim oView4 as DrawingView
iLogicVb.RunRule("CalcMaxValues")
Dim DScaleSize = 150
Dim ViewScale = DScaleSize / MaxMax
Dim Scale20 = (ViewScale/100)*20
Dim IsoScale = ViewScale-Scale20
    oPartDoc = ThisDoc.Document
    'Define IDW Template File Location    oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "R:\Drawing Library\INVENTOR\Templates\Craig Templates\IDW PART.idw", True)
    oSheet = oDrawDoc.Sheets.Item(1)
    'Define 2d view bottom left corner points for four views - sets the location to place the views (x,y) coordinates    oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(10, 14)
    oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(10, 30)
    oPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(35, 14)
    oPoint4 = ThisApplication.TransientGeometry.CreatePoint2d(50, 32)
    oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, ViewScale,kFrontViewOrientation, kHiddenLineDrawingViewStyle, "Default")
    oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint2, kHiddenLineDrawingViewStyle, ViewScale)
    oView3 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint3, kHiddenLineDrawingViewStyle, ViewScale)
    oView4 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint4, kHiddenLineDrawingViewStyle, IsoScale)
                'get the path and file name of the selected item                Dim CurFileName = ThisDoc.ModelDocument.FullFileName
                'find the postion Of the last backslash In the path                Dim FNamePos = InStrRev(CurFileName, "\", -1)
                'get the file name with the file extension                Dim Name = Right(CurFileName, Len(CurFileName) - FNamePos)
                'get the file name (without extension)                Dim ShortName = Left(Name, Len(Name) - 4)
                'get the path of the folder containing the file                Dim Folder_Location = Left(CurFileName, Len(CurFileName) - Len(Name))
                Dim strFolder As String = Folder_Location & iProperties.Value("Summary", "Title")
                'ThisDoc.Document.SaveAs(strFolder & (".dwg") , True)
    oDrawDoc.SaveAs(strFolder & ".idw" , False)
    oDrawDoc.Close(False)
    DrawingDoc = ThisApplication.Documents.Open(strFolder & ".idw" , True)
the problem i am having is that because my program is seperate, it can't find where the Measure.ExtentsLEngth is stored. eg/ Inventor.MeasureTools.Measure.ExtentsLength
I need to know where the function for measuring the extents are.
Curtis_Waguespack
Hi craigzcool,
This thread might help:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Extents-of-parts/m-p/1869988
Keep in mind you'll likely find better search results on the customization forum for programming questions:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
jletcher
Well Curtis is alot better at this then I am so I will let him lead you from here. Smiley Happy
