Someone please see the pdf attachment where i have a section view, which is not coming correctly.
But for the simple one part i found the section view ok . I am using inventor 2012
Nazim
Solved by dan_inv09. Go to Solution.
Hello Nazim,
Sorry, I can't see the problem clearly because the resolution is not high when I zoom in the section view.
Could you please upload one detail view of the section view?
Guy
Thank you for response.
I attached one idw file for your review.In the section view some profiles are coming which shouldn't be there. i pointed those by arrow
Thank you
nazim
Just a thought:
If you right click on them in the browser, what is checked under Section Participation?
It looks like they are structural steel shapes - did they come from the content center? If so the Section Participation options may be grayed out. If so, edit the view - on the Display Options tab you can change the Section Standard Parts setting.
Thank you for reply. Problem is solved when i change the participation to section.
But i can not get the the section editing command under the the display tab
anyway thank you
Nazim
You can get the option via edit the view and selct the tab "display option"
Attach will show you in detail.
Guy
