Inventor General
Distinguished Contributor
amasva
Message 1 of 4 (609 Views)
pos rep, view rep and ilogic
609 Views, 3 Replies
03-15-2012 12:32 AM
Hi
Is it in ilogic possible to check which pos rep that is active using a rule? Is it possible to activate a view rep using a rule?
I'd like to do something like:
If this "pos rep name" is active, then activate this "view rep name"
Asle Martin Svastuen
Autodesk Product Design Suite Ulitmate 2012 Sp1 / Vault Collaboration 2012 Sp1
HP EliteBook 8560w
Intel(R)Core(TM) i7 CPU Q 720 @ 2,0GHz 2,0GHz
16GB RAM
Windows 7 X64 SP1
Employee
Yijiang.Cai
Message 2 of 4 (601 Views)
Re: pos rep, view rep and ilogic
03-15-2012 02:01 AM in reply to: amasva
I did not get the existing function in iLogic, but this can be accomplished via Inventor API -
Sub Main()
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As AssemblyComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    Dim sActivePR As String
    sActivePV = oCompDef.RepresentationsManager.ActivePositionalRepresentation.Name
    Dim sActiveDV As String
    sActiveDV = oCompDef.RepresentationsManager.ActiveDesignViewRepresentation.Name
    Dim sActiveLOD As String
    sActiveLOD = oCompDef.RepresentationsManager.ActiveLevelOfDetailRepresentation.Name
End Sub
And you could also use this code sample in iLogic, and maybe the error shows up, and you could remove the "Set" in code line to fix it.
River
River Cai
Inventor Quality Assurance Team
Curtis_Waguespack
Message 3 of 4 (586 Views)
03-15-2012 09:27 AM in reply to: amasva
Hi amasva,
Here is an example that might help, along with some sample files.
I hope this helps.
Curtis
' set a reference to the assembly component definintion.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'toggle Between Positional Representations
If oAsmCompDef.RepresentationsManager.ActivePositionalRepresentation.Name = "Master" Then
oAsmCompDef.RepresentationsManager.PositionalRepresentations.Item("Stacked").activate
ElseIf oAsmCompDef.RepresentationsManager.ActivePositionalRepresentation.Name = "Stacked" Then
oAsmCompDef.RepresentationsManager.PositionalRepresentations.Item("Master").activate
End if
'set View Representation based on of the active Positional Representation
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Blue").activate
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Red").activate
End if
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
amasva
Message 4 of 4 (572 Views)
03-15-2012 11:22 PM in reply to: Curtis_Waguespack
Thank you very much Curtis :smileyhappy:
HP EliteBook 8560w
16GB RAM
Windows 7 X64 SP1
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
