I am facing little problem regarding hole command.
I have to create hole on cylindrical part. and that hole is at an angle 15 degaree from vertical axis. This hole is on 200 mm pcd. ( find attachement)
I have create that hole without drawing sketch. As we do in linear option.
Pls help.
Thanks and Regards,
Datta Indalkar
@Anonymous wrote:I have create that hole without drawing sketch.
Why can't you use a sketch point?
