Inventor General
Active Contributor
Message 1 of 2 (100 Views)
pls help
100 Views, 1 Replies
07-09-2012 04:01 AM
I am facing little problem regarding hole command.
I  have to create hole on cylindrical part. and that hole is at an angle 15 degaree from vertical axis. This hole is on 200 mm pcd. ( find attachement)
I have create that hole without drawing sketch. As we do in linear option.
Pls help.
Thanks and Regards,
Datta Indalkar
With Warm Regards,
Datta Indalkar.
Message 2 of 2 (96 Views)
Re: pls help
07-09-2012 04:03 AM in reply to: indalkar.dattatray
Why can't you use a sketch point?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
