Inventor Forum
placing constraints
4 REPLIES 4
203 Views, 4 Replies
placing constraints
I am building a patio, I have a croos beam that needs to have a 1% slope to
it for drainage. I have one beam attached to the structure and another
support beam out about 20'. The beam attached to the structure is a couple
of inch's higher in elevation than the other support beam. How do I get a
cross beam to constrain to each beam independently giving me the slope I
need for the roof that is to be attached to the cross beams? I have tried
several different ways to constrain this but no luck. Any ideas would be
appreciated. Thanks,
Willie
4 REPLIES 4
I am probably misunderstanding, but can't you just use a angle constraint of 1º on the
beam attached to the structure? Maybe a simple example in customer files would help.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Willie" wrote in message
news:B391CCC08B9450A9964C635446D8E0C5@in.WebX.maYIadrTaRb...
> Willie
I tried that, I placed an angle constraint on the beam attached to the
structure, the problem is when I add the 1 degree angle it kicks the side
attached to the structure into the beam. I know I am missing something, just
cant put my finger on it.
"Kent Keller" wrote in message
news:24A253ADC5A5DD349E4EA46FBC1FF1C1@in.WebX.maYIadrTaRb...
of 1º on the
files would help.
> Kent
> Assistant Moderator
slope to
couple
a
tried
> > Willie
Figured it out, thanks for your help Kent.
to
> Willie
Ok.. well I had just posted a example to customer files. 8^) Oh well glad to hear you
figured it out.
Kent
Assistant Moderator
news:F4056EC8023DFBA817DD3FB381E2181B@in.WebX.maYIadrTaRb...
