I tried that, I placed an angle constraint on the beam attached to the
structure, the problem is when I add the 1 degree angle it kicks the side
attached to the structure into the beam. I know I am missing something, just
cant put my finger on it.
"Kent Keller" wrote in message
news:24A253ADC5A5DD349E4EA46FBC1FF1C1@in.WebX.maYIadrTaRb...
> I am probably misunderstanding, but can't you just use a angle constraint
of 1º on the
> beam attached to the structure? Maybe a simple example in customer
files would help.
> Kent
> Assistant Moderator
> Autodesk Discussion Forum Moderator Program
> "Willie" wrote in message
> news:B391CCC08B9450A9964C635446D8E0C5@in.WebX.maYIadrTaRb...
> > I am building a patio, I have a croos beam that needs to have a 1%
slope to
> > it for drainage. I have one beam attached to the structure and another
> > support beam out about 20'. The beam attached to the structure is a
couple
> > of inch's higher in elevation than the other support beam. How do I get
a
> > cross beam to constrain to each beam independently giving me the slope I
> > need for the roof that is to be attached to the cross beams? I have
tried
> > several different ways to constrain this but no luck. Any ideas would be
> > appreciated. Thanks,
> > Willie
