Edi,
I'm a bit confused, do you want to render using MDT or Inventor? There
should be an Inventor 5 newsgroup on this server that would better answer
your question about Inventor.
In any case go to http://www.mymcad.com/ and search for render. Should
answer most of your questions and keep you busy for the afternoon.
Ray
"Edi" wrote in message
news:7C30073493D6B210CBCBD80CE2EB0276@in.WebX.maYIadrTaRb...
> so basically, what you're telling me is that there is no photoreal
rendering
> option at all???
> that's too bad,
> i need a proper photreal rendering solution in order to present the
design,
> can anyone advise me how to do it? uppon exporting .iges into, say,
autocad,
> i loose all the surfaces and parts information. i am not familiar with
MCAD,
> but if this software's environment allows a natural and direct export
> /import without loosing the information plus a photoreal rendering option
> then i will look into it
