Inventor General
Distinguished Contributor ijc
ijc
Message 1 of 18 (251 Views)
pattern
251 Views, 17 Replies
05-19-2012 04:20 AM
From the IV2013 model i`ve attached can i do the following
1. Extrusion 2   -   can i just make 1 extrude (instead of 6 )
2. Can i then do 1 Split and 1 Loft Cut to Extrusion 2
3. Pattern/mirror the above
cause i have to do the Loft Cut individually to each one of the extrudes in Extrusion 2.I tried new solid,mirror and pattern but neither worked.Is there a time saving way or simpler way to achieve
Thanks IJC
trumpy81
Message 2 of 18 (215 Views)
Re: pattern
05-19-2012 10:15 PM in reply to: ijc
I looked at your model and I'm not sure of the best way to advise you as I don't know what your modelling intent is or what parameters you have to work with. Like with most things, there is more than one way to achieve a common goal.
I would advise that you use the 'draft' command instead of loft to add the angle to the fins. This will reduce the number of operations needed as you are able to 'draft' all the fins in one go. You will need to do that four times, but that is a lot less than the individual lofts you are curently using.
You could also use a revolve cut to add the angles in one go, but it really depends on the design intent here.
You should only use the mirror command when you have all the details to be mirrored, complete. This can save a little time as you only have to work on one side of the part.
I assume, that this is an electric motor casing, and in the real world this part would be cast, yes?
If so, try to envisage the finished cast part. Sometimes it is easier to draw the entire outline in one go rather than breaking it up into smaller pieces. You can then use the various tools that Inventor offers, to shape the finer details, like the angled ends of the fins for example.
And since this would be a cast part, don't forget that any details, like the fins, must be slightly angled so that the mold pattern can be removed from the mold easily. It is best to include these types of details right from the beginning.
How you draw it depends a lot on the actual dimensions you have to work with. If you have complete flexibility in those dimesions then there are any number of ways to model it. If you are modelling an existing piece, then you are a little more constrained (IE: your dimensions and other details are already set).
Good luck with your model and if you have any other questions just holler!
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
ijc
Message 3 of 18 (212 Views)
Re: pattern
05-19-2012 10:48 PM in reply to: trumpy81
Hi Andy
Thank you for the advice.Some good points.
I did try the revolve cut but the result was not uniformed.Top of the fins were longer in the middle then the outsides.I used the Loft as it gave me a uniformed angle on all/each fin.I though there might be a way i could do it in less steps.
Is there a way the Draft tool could achieve what the Loft achieved?
Thanks again for your help
IJC
trumpy81
Message 4 of 18 (189 Views)
Re: pattern
05-21-2012 12:32 AM in reply to: ijc
Yes, the draft tool will achieve exactly what the loft tool did. It can be a little tricky when selecting the correct face to draft but otherwise it will give the same results.
The curved cut in the revolve is the result of the differing protusion of each fin as it revolves around the center axis. If all the fins were the same length/width when you cut them using revolve, then you would get a uniform angle.
Try making the fins equidistant, then revolve cut the angled ends then either extrude cut the fins to width or do another revolve cut with an offset axis and larger diameter.
Again, it depends on your design intent. Will this part be manufactured at all, or is this just a model?
Regards
Andy M
ijc
Message 5 of 18 (182 Views)
Re: pattern
05-21-2012 04:04 AM in reply to: trumpy81
It will be a model.How can the draft tool achieve the same result as the Loft but all in 1 go
IJC
ijc
Message 6 of 18 (158 Views)
Re: pattern
05-21-2012 01:57 PM in reply to: ijc
Any chance of an example on how to use the Draft Tool to get the same result as the Loft.I tried with the Draft tool but i could not get the same result.
Same for the revolve cut:Try making the fins equidistant, then revolve cut the angled ends then either extrude cut the fins to width or do another revolve cut with an offset axis and larger diameter.Any chance of an example
Would be useful to me if i could see both of these examples and i could use these for future modelling
IJC
trumpy81
Message 7 of 18 (149 Views)
Re: pattern
05-21-2012 09:34 PM in reply to: ijc
IJC
I have done a sample part for you based on what I remember of your part. Dimensions etc... should probably be ignored. I did find that the revolve cut gave the same results that you showed, I don't know why that is?
You'll see that I added fins on the end so that I could show the draft command in action. I hope this helps.
Regards
Andy M
ijc
Message 8 of 18 (137 Views)
Re: pattern
05-22-2012 03:53 AM in reply to: ijc
Thanks Andy
It looks like the Loft done individually is the way to get the Fins all equal.I thought there might be a way to do this but with a fewer steps
IJC
trumpy81
Message 9 of 18 (129 Views)
Re: pattern
05-22-2012 04:29 AM in reply to: ijc
Did you not see the fins on the end using draft?
They are all level.
Regards
Andy M
ijc
Message 10 of 18 (124 Views)
Re: pattern
05-22-2012 04:37 AM in reply to: trumpy81
Yes i did.Thanks.I was able to achieve that but the fins are going around the case in which i could not reproduce the same result with Draft tool
I was hoping for the same affect though on the fins running along the case (see my attached file on the 1st post) in which for me to get the desired shape i had to do each fin individually by using the Loft cut
IJC .
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
