Inventor General
Distinguished Contributor
JimSteinmeyer
Message 1 of 9 (236 Views)
part not found in vault. But it's there?
236 Views, 8 Replies
10-23-2012 09:48 AM
First, we just updated to 2013 from 2012 last week.--Could be key to problem--
I just attempted to open a drawing from the Vault (basic) and was informed that the drawing was unable to open because it was unable to find one part of the assembly. I broused to the component location and.....it was there. Then I attempted to open the component and was informed again that the part did not exist and I should locate it.
Can anyone suggest how to figure out either what happened, or atleast map to a new part so the file will at least open if roll back state or something?
Thank you
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
JimSteinmeyer
Message 2 of 9 (232 Views)
Re: part not found in vault. But it's there?
10-23-2012 10:03 AM in reply to: JimSteinmeyer
this gets more interesting, I just checked an assembly I opened just before attempting yto open the problem file , and the missing part was in there. I have started Vault and Inventor, but no    success.
Jim
HP G71 notebook
Win 7 home premium
*Pro
ampster
Message 3 of 9 (224 Views)
10-23-2012 10:33 AM in reply to: JimSteinmeyer
the files stored in the Vault need to be migrated to the new version before you attempt to open them in 2013.  Has that been done yet?
JimSteinmeyer
Message 4 of 9 (211 Views)
10-23-2012 01:18 PM in reply to: ampster
How do I go about migrating files without checking them out? Up until now (4 days) we have not had problems with this.If we attempt to open a vaulted file we get a message that the file will be migrated when saved, but everything opens fine. Now as far as the rest of updating, that hasn't gone near as well. Enough to encourage someone to wait 4-5 years between upgrades. Plus with the money saved from subcriptions and purchasing up graded add ins The software is much more afordable.
Jim
HP G71 notebook
Win 7 home premium
Valued Mentor
BLHDrafting
Message 5 of 9 (200 Views)
10-23-2012 06:59 PM in reply to: JimSteinmeyer
When we do version upgrades we migrate all Library and Project files (ipt, iam, idw, ipn, etc..) using the Task Scheduler. The process is a bit hit an miss sometjimes. I have found that doing about 500 files at a time works nearly every time. You set up a Task to checkout files (or a directory), then another to do the migration (read the help files-there are some tricks here) and then another to check the files back in. All of this is done before any file is openend in the new Inventor version.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
xdumont
Message 6 of 9 (188 Views)
10-23-2012 11:57 PM in reply to: JimSteinmeyer
Just to know, did you perform a purge in 2012 before migrating to 2013?
*Pro
ampster
Message 7 of 9 (173 Views)
10-24-2012 05:13 AM in reply to: BLHDrafting
to add to Brendan's post, you should practice doing the migration in the order Brendan listed, do the ipt's first, then do the iam's, then the idw's...etc and this is done on the Vault server itself.
karthur1
Message 8 of 9 (159 Views)
10-24-2012 06:08 AM in reply to: ampster
ampster wrote:
the files stored in the Vault need to be migrated to the new version before you attempt to open them in 2013.....
I think what ampster is saying is that the vault data will have to be migrated.  The vault data migration is normally an automatic process when you upgrade vault form one version to the next. Vault does not care what Inventor version the data is in (I'm not sure that it even knows, but it might).
Inventor files DO NOT have to be migrated before they are placed in vault.
Jim,
Go to Vault Explorer and browse to the Clevis coupler.ipt.  Right click and select "Open".  Does this part open in Inventor or do you get the same error as your original post?
Does the "Where Used" tab for the part show anything?
Kirk
JimSteinmeyer
Message 9 of 9 (140 Views)
10-25-2012 03:07 PM in reply to: karthur1
Sorry for the delay in getting back to this but other fires and all. The fijles were migrated when the Vault was updated. Kirk, I just went to the vault  and, yes the clevis does check out this time. So I guess things are working as to this guestion anyway. I am going to find and install any hot fixes available now.
Thank you all.
Jim
HP G71 notebook
Win 7 home premium
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
