Inventor General
Active Contributor
sam__gleeson
Message 1 of 7 (294 Views)
part in sheet metal
294 Views, 6 Replies
11-23-2012 04:54 PM
Part attached is made from solid modelling.How can this part be made as a sheet metal part.....i`m not familiar yet with sheet metal....wanting to learn
Sam
INV 2013
*Pro
sbixler
Message 2 of 7 (266 Views)
Re: part in sheet metal
11-24-2012 07:08 PM in reply to: sam__gleeson
Here you go.  Using Contour Flange is much quicker than doing it the conventional way.  But I notice in your model that the two bottom flanges are thicker than the rest of the model (3 instead of 2).  If that's really what you need, you can't do it in sheet metal (and I also wonder how it would be fabricated).
Active Contributor
sam__gleeson
Message 3 of 7 (255 Views)
11-25-2012 02:30 AM in reply to: sbixler
Hello Sam
Thanks alot.
Sam
JDMather
Message 4 of 7 (243 Views)
11-25-2012 07:04 AM in reply to: sam__gleeson
Thanks alot.
But his solution is incorrect for a sheet metal part.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Contributor
sam__gleeson
Message 5 of 7 (183 Views)
11-26-2012 01:57 AM in reply to: sam__gleeson
OK JD...can you post your file then and i can then compare/see the differences
Sam
*Pro
sbixler
Message 6 of 7 (167 Views)
11-26-2012 04:06 AM in reply to: sam__gleeson
JD's right, that my part is not correct-- but how you correct it depends on the design constraints.  If the edges that currently show as beveled in my part (and yours) are in contact with something else, then it matters whether the inside or outside edge is the correct dimension.  On the other hand, if the cutouts are just giving something else a wide clearance, then it's pretty easy to correct.  In any case, JD has done it properly for one of those cases, so maybe he'll post it.  Otherwise, tell us what the beveled edges' function is and I'll try to make it work for you.
JDMather
Message 7 of 7 (158 Views)
11-26-2012 05:01 AM in reply to: sam__gleeson
As indicated by Sam B the design intent for that corner where the angle crosses a bend is very important.
In the end you want a Flat Pattern where all of the edges are perpendicular to the flat.  This is easiest to check in wireframe shade mode.
Examine the attached file carefully in the bent angle corner for one possible solution.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
