Inventor General
Active Member
nlovan
Message 1 of 17 (1,697 Views)
ordinate dimensions
1697 Views, 16 Replies
04-23-2010 07:36 AM
How do I rotate my value(s) on the verticle ordinate dimension verticle?
*Dennis Jeffrey
Message 2 of 17 (1,697 Views)
Re: ordinate dimensions
04-23-2010 07:53 AM in reply to: nlovan
The best way is to create a new ordinate dimension style that reflects
the vertical text orientation.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Subscribe to the free "The Creative Inventor Magazine now available at:
http://teknigroup.com/CI-Subscribe-Login.asp
Active Member
nlovan
Message 3 of 17 (1,699 Views)
04-23-2010 08:32 AM in reply to: nlovan
How do you create a new ordinate dimension style that reflects the verticle text orientation?
*Dennis Jeffrey
Message 4 of 17 (1,702 Views)
04-23-2010 08:38 AM in reply to: nlovan
The Styles Editor under the Manage tab while in an IDW. Have you worked
with styles? This can be a complicated subject. Might check out the
Styles tutorials at:
http://mfgcommunity.autodesk.com/blogs/blog/view/6/Everything_You_Need_Know_About/
If you still have problems post back!
New Member
danchapman
Message 5 of 17 (1,705 Views)
05-25-2010 10:23 AM in reply to: nlovan
I am also having the same issue. I want to make my ordinate dimension text appear in the vertical orientation. I thought I had it figured out by setting the text style to a 90 deg. angle. I also made this text style referenced in my dimension style. However, it did not work. It works on the note text boxes but not with the dimension text.
mcgyvr
Message 6 of 17 (1,705 Views)
05-25-2010 11:08 AM in reply to: nlovan
easiest way is to just change this option in the style editor that I have highlighted in the attached image.
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
New Member
danchapman
Message 7 of 17 (1,705 Views)
05-25-2010 11:32 AM in reply to: nlovan
Thanks. I had passed over that box.
Bill.Schmid
Message 8 of 17 (1,307 Views)
03-21-2012 10:48 AM in reply to: mcgyvr
Hi.  I just found this thread.  I was looking for the same thing.  Like shown in this picture from the help.  I wanted my text to be in-line with the leaders.  It looks like that's been answered, but does this mean that I need a separate dimension style for my ordinate dimensions if I don't want my regular dimensions to have the text rotated?
Bill
Bill Schmid
AutoCAD Mechanical 2011
Valued Mentor
Rich.O.3d
Message 9 of 17 (1,282 Views)
03-21-2012 07:11 PM in reply to: nlovan
The solution below is from 2010...that switch does not control the ordinate dimensions in Inventor 2012
eg below
note: same dimstyle for linear and ordinate dims
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
*Pro
sbixler
Message 10 of 17 (1,261 Views)
03-22-2012 04:51 AM in reply to: Bill.Schmid
If you don't want normal linear dimensions rotated, then you will need two different dimension styles.  But you can set your Object Defaults style to default to the appropriate style for each dimension type.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
