Inventor Forum
open drawing
4 REPLIES 4
762 Views, 4 Replies
open drawing
Hi Guys
When I open Drawing of a part in the assembly (Right click on the part and Select  "open drawing"  ) , inventor (2013) cant open drawing and i see Attachment massage.
4 REPLIES 4
MariaManuela
To be able to open a drawing, the same must be the name of the 3D file and be in the same folder as parent file.
Regards
Asidek Consultant Specialist
www.asidek.es
sam_m
what's the filename for the part and the filename for the drawing?
I think it only works if they equal - ie 1234.ipt will only open 1234.idw - if you have added anything to the filename it will not be able to automatically find it, and thus why you have the dialog box asking to find it.  I can't remember if it also needs to be in the same folder as the part/assemble file, probably the case.
If you're using Vault then it might also be because the idw is still in the Vault and needs to be "got" to copy to the work drive so Inventor can find it.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Cadmanto
This confirms what is being said here.  This is right out of the help file.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
DeconSmal
in reply to: Cadmanto
My company maintains drawings with a different file name than the model files. Is there an iLogic rule that can be written to circumvent identical file names, excluding the extension of course.
Example of what our file names look like.
Part and assembly files: ABC-12345-0001 - DESCRIPTION_1.ipt, iam, ABC-12345-0002 - DESCRIPTION_2.ipt, etc.
(where the "0001" and "DESCRIPTION" will change. The pre-fix and drawing number will remain the same throughout the design, ie ABC-12345.)
Drawing files: ABC-12345-0001-01.idw, ABC-12345-0002-02.idw, ABC-12345-0003-03.idw, etc.
I have written a few simple iLogic rules but am not very "program lingo" literate. Please help if this can be achived!
DeconSmal
