Inventor General
Active Contributor
Message 1 of 9 (1,916 Views)
Accepted Solution
offset ellipse?
1916 Views, 8 Replies
02-07-2012 11:16 AM
Hello everyone,
I am having trouble creating an extrude-cut from an offset ellipse.  It seems that when the ellipse is offset, it becomes an associative spline.  I need it to remain associative with the original ellipse.
But, when I try to extrude a profile using the new spline, it won't recognize the edge.
I can't just create a new ellipse, as it's profile won't quite match the offset one.  I tried tracing over the ellipse with a spline, but it then requires a vast amount of dimensions to constrain it all together.
I'm trying to extrude-cut the red outlined profile (including the elliptical part of course)..
Here is the part.  I am working in Inventor 2009.
Thanks for any ideas,
Joe
*Expert Elite*
Message 2 of 9 (1,903 Views)
Re: offset ellipse?
02-07-2012 12:39 PM in reply to: jstraub78
When you offset an ellipse there are two possible solutions
1. offset equal distant - not a mathematical ellipse (usually better to Shell feature rather than offset spline).
2. True ellipse offset (seldom used - depends on where you click the ellipse to offset.
The two different solutions might not be easily noticed depending on the ratio of the minor and major axis.
see http://home.pct.edu/~jmather/skillsusa%20university.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
*Expert Elite*
Message 3 of 9 (1,901 Views)
Re: offset ellipse?
02-07-2012 12:42 PM in reply to: jstraub78
oops, see Tip 34 pg 11
*Expert Elite*
Message 4 of 9 (1,898 Views)
Re: offset ellipse?
02-07-2012 12:47 PM in reply to: JDMather
After experimenting a bit with your part  - I think you might have found a bug.
To know for sure I would have to recreate from scratch in 2012 to see if it can be reproduced.
Active Contributor
Message 5 of 9 (1,873 Views)
Re: offset ellipse?
02-08-2012 06:25 AM in reply to: JDMather
If I offset where one of the axis is present, I think that is treated independantly from the original ellipse.
I need to maintain the same offset distance around the entire ellipse and the offset ellipse needs to react to changes made to the original ellipse.
So, I offset the other way, which I believe creates an associative spline instead of an ellipse.  I don't think it's mathematically possible for it to stay as an ellipse and maintain the same offset the entire way around.
Did you mean tip #32?  If so, I believe I want the ellipse on the left.
Hmmm...I'm not sure if it is a bug or just something I'm missing.  Is it possible to save a part created by Inventor 2012 back as a file that I could open in 2009?  Maybe I'd be ok if I had a template part that works that I could tweak/apply my dimensions to.
I went to Penn College for CAD, but it was pre-Inventor days....('97-'99).  For what it's worth, I can still make a mean 3D Solid Model in AutoCAD...
Joe
*Expert Elite*
Message 6 of 9 (1,859 Views)
Re: offset ellipse?
02-08-2012 08:45 AM in reply to: jstraub78
Did 2009 have the Sculpt tool?
Not sure what you are after - but I extruded the ellipse as a surface midplane (I used 5" but distance doesn't matter as long as it goes through the part.
Shared the sketch and extruded the lines midplane by same distance.
(eariler could not trim the elllipse with the lines)
Extend Surface the two edges of the second extrude beyond the ellipse.
Sculpt - Cut the volume between the surfaces.
You might want to check out the surfacing tutorials in my signature.
*Expert Elite*
Message 7 of 9 (1,857 Views)
Re: offset ellipse?
02-08-2012 08:48 AM in reply to: JDMather
or this?
*Expert Elite*
Message 8 of 9 (1,852 Views)
Re: offset ellipse?
02-08-2012 09:07 AM in reply to: jstraub78
jstraub78 wrote:
 ....I can still make a mean 3D Solid Model in AutoCAD...
What is this "AutoCAD" you speak of?
Is that what they taught in the last century?
Active Contributor
Message 9 of 9 (1,845 Views)
Re: offset ellipse?
02-08-2012 10:48 AM in reply to: JDMather
Wow, I'm not very versed in working with Inventor Surfaces, but your figure/explanation taught me something new today!
The first option you have listed is what I was trying to achieve.
As for my AutoCAD comment....well, I did prefix my statement with "for what it's worth..."  I figured I'd leave that open for interpretation :smileywink:
Thank you very much for the help, this was turning into a bit of a roadblock for me...
Joe
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
