Inventor Forum
nuts & bolts
4 REPLIES 4
339 Views, 4 Replies
nuts & bolts
Greetings
I have modelled up a nut and bolt.
1. Have i matched the thread size correctly.I made the bolt thread the same size as the nut thread size
2. I see these in the Content centre but if i want to make my own nuts & bolts with various sizes what do you suggest.I can then just select the required sizes
3. How do you name your nuts & bolts.How would you name what i attached
Thanks for any help
Lou
Inventor -- 2013
4 REPLIES 4
stephengibson76
publish your own content centre library or download iparts from somewhere like here
http://www.cbliss.com/inventor/Parts/index.htm
I wouldnt bother creating your own, its been done many times before...
Stephen Gibson
View stephen gibson's profile on LinkedIn
in reply to: stephengibson76
Thank you
Would it be best to just use the Content Centre?
Can the nuts/bolts from Content Centre have there colors changed?
Thanks again
stephengibson76
I used to hate content centre along with many others which is why there are so many ipart librarys floating around.  That said, I have been forced to use it in my current job and it has improved drastically over the years.  Copying content centre librarys to your own custom library, you can do what you want with, (material colour etc) so this would suit your needs...
One thing to be aware of when your searching for help, use the wrong spelling for centre, center... I know, I know... they still use some strange pre history measuring methods over the pond as well, dating from the era when apes turned to humanoids and we still had 12 fingers 😉
Stephen Gibson
Thanks Stephen
