I have a face plate with strokes on it to represent pressure increments.I cannot get the numbers onto the face plate.On the large stroke it starts at 0 and goes to 9 .. please how do i add the numbers.Also i used extrusions for the increment strokes with circular patterns and mirror features.Is this how it should be modelled?
2013 EDU
Jason
Solved by mcgyvr. Go to Solution.
Simply start a new sketch and then click the text tool.
Exit sketch and then Extrude cut or Emboss the text.
@jasonraul wrote:It looks like i need to do a sketch for each number...it this correct
No..not correct..You could have 1 sketch with all the strokes and even all the text in that same sketch if you want.
@jasonraul wrote:how do i do 1 sketch for the lot...numbers and hash .. i`m lost now
Not sure what to tell you here.. Have you ever used Inventor before?
Simply start a new sketch.. using the text feature add a number.. use the text feature again..add another number,etc..
same can be done with the hash marks too.. In that same sketch create the one hash mark then do a circular pattern while still in the active sketch.. When you are all done finish the sketch and then extrude.
