I added a hole thread feature, npt 3/8 . Inventor is removing material. This is different from the npt charts.
Any idea why the difference ?
Dan
OK, can you elaborate please. Why inventor is creating that "step" ?
Dan
The minor diameter is too small, recommended tap drill for 3/8 NPT is 9/16. If you change the tap drill in the Thread.xls to .5625 the step should go away.
