Inventor Forum
not the same flexible hose question
4 REPLIES 4
213 Views, 4 Replies
I have had success creating flexible hose assemblies in larger assemblies, however I need to make drawings of these hoses in a straight configuration. You know, cut hose to this length, swage on fittings. How can I use the same model in the drawing as in the assembly. I was thinking if driving the node points to be constrained to a line in the drawing representation.
Thomas
IV11sp2
4 REPLIES 4
Personally, I would do this in a note, instead of creating another view that
shows the overall size.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://teknigroup.com
wrote in message news:5701780@discussion.autodesk.com...
Thomas
IV11sp2
dan_inv09
Or a tabulated drawing for several hoses with one general, broken view.
What's the value of showing ten feet of half inch hose and wasting a bunch of extra pieces of paper?
I would just add the unit length to my BOM table and have each hose length
shown in your BOM. You can get each hose length as well as a rolled up
length.
Dell 670 dual Xeon - 3.2
3gb memory, SCSI320-15k
XP-Pro, sp2
Quadro FX3400: Driver: 91.36 OpenGL
IV2008-pro sp1, SpacePilot Rel V: 3.4.2 Dvr V: 6.3.3
wrote in message news:5701854@discussion.autodesk.com...
I am trying to keep associativity between the part and the drawing. I want to be able to route a hose through an assembly as i see fit and not care about its length or shape. Then have a drawing that shows the same assembly with the hose straight, not routed. I am aware that I could make a dumb drawing, but I then need to make sure they always match. Also, who wants a routed shape on their drawing unless the hose was thermomolded to that shape.
