Inventor Forum
not able to add fillet
13 REPLIES 13
Message 1 of 14
andy_tap
696 Views, 13 Replies
The centre of the part where Loft1 ends i am unable to apply fillet.Also cannot apply fillet where Extrusion1 and Loft1 join.I want to have a blended appearance instead of the join lines.Maybe i have used the wrong process for this part but can a fileet apply to this section?
Andy
13 REPLIES 13
Message 2 of 14
rdyson
in reply to: andy_tap
You can use a face fillet of upt to 3 mm (at least in 2015)
Then it get interesting. Between 3 and 30mm, the part disappeares except for hte fillet surface and the part in fact becomes just that surface. About 30mm, the fillet fails.
PDSU 2016
Message 3 of 14
JDMather
My attempt.
Message 4 of 14
WHolzwarth
Here's another way of doing.
I could get an acceptable outside look, but no shell could be done with 2015.
Smiley Wink Never mind. We've got the Home menu in 2015, as substitute.
Walter
Walter Holzwarth
Message 5 of 14
WHolzwarth
in reply to: WHolzwarth
I've been thinking again about shelling. Well, this should be easier.
Walter
Walter Holzwarth
Message 6 of 14
johnsonshiue
Hi! The fillet can be done but you have to use variable radius fillet, not constant radius fillet. The difficult area is at the top where the loft meets with the extrusion. The fillet has to undergo convexity change. VRF helps bypasses the singularity. Please take a look at the attached part and see if it is what you are after.
Thanks!
Software Test Engineer
Message 7 of 14
WHolzwarth
in reply to: johnsonshiue
Not all issues are gone, Johnson.
Walter Holzwarth
Message 8 of 14
andy_tap
thank you for some models.Unfortunately i have 2014 and was not able to open the 2015 models to view
Message 9 of 14
JDMather
I posted 2013 file.
Message 10 of 14
andy_tap
in reply to: JDMather
JD...yes and it was a good model...was just looking at all the different techniques but the 2015 i am unable to open
Message 11 of 14
JDMather
A fillet will remove material (the "hump" must lose height).
How did you determine your 77mm "height"?  Did you take into account that fillet will remove material height?
Do you have a picture or traditional 2d drawing of what you are trying to achieve?
Message 12 of 14
andy_tap
I will post a picture later on today
Message 13 of 14
WHolzwarth
Here's a version for 2014. I prefer the larger fillet at the center (Loft2 instead of Fillet2)
Walter
Walter Holzwarth
Message 14 of 14
andy_tap
nice model Walter...thanks
