style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Thanks Hugh! and yes you do seem to
be somewhat caught up in the whole gearhead thing (to say the
least)...........counseling is an option you know, but if you are happy in your
addiction then I say....have fun!
face="Times New Roman">
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">The car is very nice! and I assume
the white writing is the ET in the 1/8th?, if it is then that is flat
cooking!
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">My Nissan is not quite up to the
same performance specs as yours; (a bone stock 93 Sentra with 125K miles) but
it's still pretty peppy for what it is.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">I need to get a tach. in my 64 GMC
4000 dump flat bed so I don't over rev the old 305 V6 hence the pulse count
question (max RPM is 3800 on the old gal.) 🙂
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Albert
"Hugh Henderson (Autodesk)" <
href="mailto:discussion.support@autodesk.com">discussion.support@autodesk.com>
wrote in message
href="news:6184075@discussion.autodesk.com">news:6184075@discussion.autodesk.com...
Hi Albert,
For a four-stroke, six
cylinder engine, it takes two engine revolutions to fire
all six coils.
So, that coil pulse count you're looking
for is three (only three cylinders will fire in one engine
revolution).
Good question. I have a Nissan
inline-six cylinder turbo, and I removed the stock EFI and replaced it with an
aftermarket one. I went completely distributorless, and I'm running six
Denso coils (taken from a 2003 GMC Suburban, an LS1 engine) so I can run "coil
on plug". They have integral ignitors and I don't have to run "wasted
spark". I also run six Mazda RX7 injectors that can now fire
sequentially (versus batch-fire in the old Bosch L-Jetronic EFI). I'm a
sick gearhead. ;o)
Best regards, -Hugh
src="http://home.comcast.net/~hughhenderson/pics/6th_annual_NWZ_show_n_shine/hughdogz.JPG"
align=baseline border=0>
size=2>
Hi Albert,
cooking!>>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Actually, it is just a random
number given when I received my racing permit. I run the 1/4 mile
drag at Portland International Raceway. Stock, the engine is 180
horsepower and runs ~16.5 seconds in the 1/4 mile (0-400 meter). Last
season, I was able to get it down to 14.1 seconds.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Here is a video of me racing
my buddie who also has a 280ZX:
href="http://www.youtube.com/watch?v=cmDyyxdzgw8">http://www.youtube.com/watch?v=cmDyyxdzgw8
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> I'm in the process of
building the engine up some more. Installing a hybrid T3/T04E
turbochanger, I ported the head and did a bunch more work to it, ported the
exhaust manifold, made a 3-inch downpipe and 3" mandrel bent exhaust (welded
together 38 pieces total with six v-band clamps for easy dissasembly).
Then I purchased a SPEC flywheel, pressure plate and six-puck friction
disk. I'm hoping to get into the 12's. 8o)
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><<
it's still pretty peppy for what it is.>>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Those are great cars!
If it has the SR20DE engine, it has tons of potential.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> If you can get your hands on
a MSD 6AL capacitive discharge ignition system, you can take advantage of the
"soft rev" limiter. Just slip in a different "pill" to change
the max RPM.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Thanks for the great comments
Guys!!
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Sincerely
-Hugh
"Dennis Jeffrey" <
href="mailto:djeffrey@teknigroup.com">djeffrey@teknigroup.com> wrote in
message
href="news:6184690@discussion.autodesk.com">news:6184690@discussion.autodesk.com...
My previous answer is wrong. 1/2 rotation per
stroke.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008
SP3, AIP 2009-SP1 PcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT
512MB
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
"Albert Allen" <
href="mailto:albert@sno-cat.com">albert@sno-cat.com> wrote in message
href="news:6184725@discussion.autodesk.com">news:6184725@discussion.autodesk.com...
This is great I got all you deep thinkers digging
even deeper into the grey matter!
Anyway, my read is on a single cylinder 4 stroke
engine, there would be 2 revolutions of the crank for each time
the coil field collapses.
So on a 6 cylinder engine there should be 3 power
strokes per rev and consequently 3 coil fires per rev. (gotta have proper
ballance ya know)
So my tach dip switches should be set for 3
pulses per rev to get my proper RPM reading.
"Dennis Jeffrey" <
in message
stroke.
Expert
Expert.
AIP 2008
512MB
<pauldoubet> wrote in messageThis
href="news:6184717@discussion.autodesk.com">news:6184717@discussion.autodesk.com...
is probably not a well known fact but your old single cylinder 4 cycle push
mower does indeed fire on both the compression and the exhaust stroke.
Obviously the latter is a wasted spark, but since the breaker points are
driven off the top end of the crank shaft it fires on each revolution. So the
correct answer is once per revolution. Have a great weekend,
Paul
wrote in message
href="news:6188629@discussion.autodesk.com">news:6188629@discussion.autodesk.com...
Hi Ray,
I was under the impression that the unique
sound of a V-Twin engine resulted from the fact that the two connecting rods
share the same crank pin at a 45 degree angle (I could be wrong
though).
For all you Gearheads, here is another "Friday
Question":
Why do the European "exotic" V-8's
have a different exhaust note than the American V-8's? Hint: it has to
do with the crankshaft design.
-Hugh
